Bluetooth/using mobile phone through car's system
Hello, thanks for looking. I am in England, and the car is UK spec.
I have an XJ6 from 2003, SE trim, which has a Motorola car phone in the armrest.
Before I give up and buy an external bluetooth device for using my mobile phone in the car, is there a simple & cost effective way of converting the car phone connection so that I can jack into the car's audio/phone system with the mobile phone?
Has anyone out there (preferably in the UK) successfully hooked it up with a modern smartphone (iPhone etc.) via Bluetooth? Mobile phone systems are quite different between UK and US.
Circuit diagram anyone?
You seem to suggest that there is a dedicated bluetooth adapter for the Jag radio. Could you be a bit more specific please? Is this a standard part sold by Jaguar or a third party add-on? Where would I obtain one from? Thanks.
You need the Bluetooth module, also called the BTUM. According to H2Oboy, part numbers are as follows: C2C 39062, or 2W93-14b409-## The last two characters are the revision, usually AA, AB, AC or AD. Mine is AB and works fine. I often see them on eBay, but right now all I see is the whole setup - Jaguar Bluetooth Phone Module Interface Kit Btum PSE Mic s Type x Type XJ8 | eBay
They used to cost less than $250 from the dealer.
BrentGardner
28
04-26-2024 03:08 AM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
