Bluetooth/using mobile phone through car's system
Old May 25, 2014 | 03:56 AM
XJ6 03's Avatar
Default Bluetooth/using mobile phone through car's system
Hello, thanks for looking. I am in England, and the car is UK spec.
I have an XJ6 from 2003, SE trim, which has a Motorola car phone in the armrest.
Before I give up and buy an external bluetooth device for using my mobile phone in the car, is there a simple & cost effective way of converting the car phone connection so that I can jack into the car's audio/phone system with the mobile phone?
Old May 25, 2014 | 08:37 AM
gmcgann's Avatar
Depends on what you mean by cost effective. If you already have a phone, you need the bluetooth adapter and mic. That's around $200 US.
Old Jul 16, 2014 | 05:04 PM
Luftwaffle's Avatar
Same here. The phone seems completely functional (besides of the SIM card). When I turn the ignition on, it comes up with the familiar bleeb. Even got a separate mike attached to the ceiling.
Has anyone out there (preferably in the UK) successfully hooked it up with a modern smartphone (iPhone etc.) via Bluetooth? Mobile phone systems are quite different between UK and US.
Circuit diagram anyone?
Old Jul 17, 2014 | 11:32 PM
gmcgann's Avatar
The phones may be different but the Bluetooth standard is the same. As long as the PSE works with the UK phone, you're just replacing the hardwired connection with a wireless one.
Old Jul 18, 2014 | 04:29 AM
Luftwaffle's Avatar
You seem to suggest that there is a dedicated bluetooth adapter for the Jag radio. Could you be a bit more specific please? Is this a standard part sold by Jaguar or a third party add-on? Where would I obtain one from? Thanks.
Old Jul 18, 2014 | 06:06 PM
gmcgann's Avatar
You need the Bluetooth module, also called the BTUM. According to H2Oboy, part numbers are as follows: C2C 39062, or 2W93-14b409-## The last two characters are the revision, usually AA, AB, AC or AD. Mine is AB and works fine. I often see them on eBay, but right now all I see is the whole setup - Jaguar Bluetooth Phone Module Interface Kit Btum PSE Mic s Type x Type XJ8 | eBay
They used to cost less than $250 from the dealer.
BrentGardner
29
Dec 16, 2024 12:13 AM
Stoney85
Australia - Queensland
Jun 7, 2021 11:49 PM
DeaconHull
Aug 31, 2015 10:09 PM
pnwrs2000
Aug 28, 2015 09:31 AM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
