Headlight washer jet missing
Old 02-18-2013, 07:56 AM
jmcar's Avatar
Default Headlight washer jet missing
OK so I have just got myself an XJ6 SE and noticed that one of my headlight washer jets is missing. Part number C2C3373 - number 1 in the following diagram: https://www.jaguarforums.com/forum/a...em-jetwash-jpg
I can't see how it would have fallen into the bumper as I guess there is a hose attached and yes, there is still water coming out (quite a jet) when operated.
Any ideas? I gather these are no longer available parts direct from a Jaguar dealer. Anyone know where I can get one, even second hand would be fine.
I'm in Kent, UK.
Cheers,
Jim
Old 02-18-2013, 09:08 AM
reyesl's Avatar
Old 02-18-2013, 09:22 AM
jmcar's Avatar
Thanks,
I've emailed a request to both. The first one states they are no longer available, presumably that is new.
I'd be happy to find one from a salvage yard.
Old 02-18-2013, 12:57 PM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
These things are not a good piece of engineering IMHO. I had one blow out in 2010, had the dealer put in another, only for this to blow out a few months later. Got another one put in under warranty, and it is still there on the car and working, (touch wood).
Old 02-18-2013, 03:01 PM
jmcar's Avatar
The thing that concerns me is I think this will be an MOT failure and I'm a bit stuffed if I can't actually find a replacement part.
All this for what amounts to what should be a £2.50 bit of plastic
Old 10-25-2018, 09:44 AM
Elegancec's Avatar
One of mine has also taken off and is gone away. A replacement costs 65€ for the small plastic part with spring.
Im trying to find a cheaper one from the salvage market, but not so easy.
Does the spring break or the plastic?
Old 10-25-2018, 10:31 AM
paddyx350's Avatar
One thing that can happen is that the round dome bit that the jet fits into has two plastic clips that hold the jet. These are the bits that break and the jet disappears into the bumper. If this is what has happened to yours, bumper off and you should be able to glue the jet into the dome holder bit
Old 10-25-2018, 10:39 AM
Elegancec's Avatar
Thanks for the info, very helpful. I will check tomorrow.
Old 10-25-2018, 10:49 AM
paddyx350's Avatar
If you're taking the bumper off and haven't done it before;;
The hose connector for the headlamp wash is behind the right hand front wheel arch liner.
This on my 2003 x350, may be different location on later cars.
Disconnect this plug carefully as I broke mine and it was a real pain in the **** to find a replacement which I eventually did
It has a retaining clip that holds the male bit into the female bit that must be pulled out before the two sides of the connector will seperate.
puddled
09-22-2015 03:57 AM
philwarner
09-21-2015 11:22 AM
philwarner
09-20-2015 11:03 AM
Swagguar
09-19-2015 06:05 AM
mikimogo
09-14-2015 08:34 PM
Quick Reply: Headlight washer jet missing
