X300 Injector operation, hot and grounded by ECU?
Old 02-01-2016, 02:55 AM
iconic's Avatar
Default X300 Injector operation, hot and grounded by ECU?
Do these injectors work in the 'usual' way, no strange trickery going anywhere?
....so the injectors are 'live' (hot) feed by key ignition and are 'grounded' to cycle (inject) by the ECU (PCM)?
many thanks
Old 02-01-2016, 07:26 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Yes. You got it.
The following 2 users liked this post by sparkenzap:
Don B (02-05-2016), iconic (02-01-2016)
Old 02-01-2016, 07:52 AM
iconic's Avatar
Originally Posted by sparkenzap
Yes. You got it.
many thanks
Old 02-01-2016, 08:43 AM
sparkenzap's Avatar
BTW, the voltage on the supply lead is monitored, and the pulse width is adjusted to correct for the solenoid open time change due to voltage, according to the Jaguar training manual.
Don B (02-05-2016)
Old 02-01-2016, 09:19 AM
iconic's Avatar
thanks
Old 02-06-2016, 07:44 PM
italcarnut's Avatar
And if it fails the cam sensor is suspect.
Ubad2
03-10-2016 12:28 PM
bocatrip
02-11-2016 04:43 PM
JensenHealey
02-08-2016 05:09 AM
malc4d
02-01-2016 09:39 PM
Quicktruck
02-01-2016 07:41 AM
Quick Reply: X300 Injector operation, hot and grounded by ECU?
