X300 Injector operation, hot and grounded by ECU?
Old Feb 1, 2016 | 02:55 AM
iconic's Avatar
Default X300 Injector operation, hot and grounded by ECU?
Do these injectors work in the 'usual' way, no strange trickery going anywhere?
....so the injectors are 'live' (hot) feed by key ignition and are 'grounded' to cycle (inject) by the ECU (PCM)?
many thanks
Old Feb 1, 2016 | 07:26 AM
sparkenzap's Avatar
Yes. You got it.
Old Feb 1, 2016 | 07:52 AM
iconic's Avatar
Originally Posted by sparkenzap
Yes. You got it.
many thanks
Old Feb 1, 2016 | 08:43 AM
sparkenzap's Avatar
BTW, the voltage on the supply lead is monitored, and the pulse width is adjusted to correct for the solenoid open time change due to voltage, according to the Jaguar training manual.
Old Feb 1, 2016 | 09:19 AM
iconic's Avatar
thanks
Old Feb 6, 2016 | 07:44 PM
italcarnut's Avatar
And if it fails the cam sensor is suspect.
Ubad2
Mar 10, 2016 12:28 PM
bocatrip
Feb 11, 2016 04:43 PM
JensenHealey
Feb 8, 2016 05:09 AM
malc4d
Feb 1, 2016 09:39 PM
Quicktruck
Feb 1, 2016 07:41 AM
