tapping valves
Old 10-20-2014, 09:06 PM
blackhonor9's Avatar
Default tapping valves
What additive can I add to my oil to quiet tapping valve?
Old 10-21-2014, 05:38 AM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
Tapping valves would be unusual. It is more likely to hear a worn VVT. You could use a higher viscosity oil, but if you are convinced the valves are making the noise you should check the clearances and adjust.
Old 10-21-2014, 06:15 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
Not having hydraulic lifters it is, indeed, rare to hear of tapping from the valve train. As RJ237 says, it is much more likely that the sound you are hearing is from the VVT's. The standard answer to your question is to add a can of RESTORE to the oil. If that quietens the noise then move to a higher weight oil at the next change i.e.: 5W40.
bdboyle
11-06-2015 02:07 PM
boiler
US Southwest
10-17-2015 09:35 PM
Johncy2000
10-02-2015 01:05 AM
jjmiah217
09-28-2015 09:09 AM
Quick Reply: tapping valves
