In need of brake help!
Guest
Posts: n/a
Hey guys, I am new to the forum and have a pretty serious issue concerning the Jaguar braking system currently used in a Cobra Replica we are building for a customer. The kit uses the suspension and brakes out of what we believe to be a 1979 XJ6 or 12.
I am looking for any references to technical brake information concerning these cars, known issues, or maybe just a specialist shop that you can refer. Any tid-bit of info will be helpful.
This thing just seems like it doesnt want to stop!
Obviously the car has been assembled completely now...
Thanks guys,
James
Thanks guys,
James
Hi James. I'm new to the forums, also...as well as being a first time Jag owner.
I have a 76 XJ12, and a Haynes manual. They have the same brake setup. I will try my best to answer your questions, although I can't promise anything.
I don't know what you have tried, nor what your exact problem is. Can you give a little bit more info on it "just seems like it doesn't want to stop." Here is a section from my Haynes manual on the brake system failing (fault diagnosis):
Pedal travels almost to floor before brakes operate -
- Brake fluid level too low
- Caliper leaking
- Master cylinder leaking (bubbles in master cylinder fluid)
- Brake flex hose leaking
- Brake line fractured
- Brake system unions loose
- Pad linings over 75% worn
Brake pedal feels springy
- New pads not yet bedded in
- Brake discs badly worn or craked
- Master cylinder securing nuts loose
Brake pedal feels spongy and soggy
- Caliper leaking
- Master cylinder leaking (bubbles in master cylinder reservoir)
- Brake pipe line or flex hose leaking
- Unions in brake system loose
Excessive effort required to brake car
- Pad lining worn badly
- New pads recently fitted - not yet bedded-in
- Harder pads fitted than standard causing increase in pedal pressure
- Pads or discs contaminated with oil, grease or hydraulic fluid
- Servo unit inoperative or faulty
Brakes uneven and pull to one side
- Pads or discs contaminated with oil, grease, or hydrolic fluid
- Tire pressures unequal
- Brake caliper loose
- Brake pads fitted incorrectly
- Different types of pads fitted at each wheel
- Anchorages for front or rear suspension loose
- Brakes discs badly worn, cracked, or distorted
Brakes tend to bind, drag, or lock-on
- Air in hydraulic system
- Caliper pistons seized
- Handbrake cables too tight
- Fault in servo unit
After typing all that out, I'd first check your vacuum lines. The brake system is connected to the vacuum system.
- Caliper leaking
- Caliper leaking
Guest
Posts: n/a
Sorry about the blandness of my first post.
There is excessive effort required to bring the car to a stop. From looking around I almost feel like we should be trying new rotors first.
Does anyone have suggestions on a reputable shop to deal with for Jag rotors? Experience is key since this setup is rather strange.
M0t0rm0uth - thanks so much for the time you put into your responce. It is greatly appreciated.
I know that you are looking for the best parts possible, but I just picked up a set of drilled and slotted rotors from a dealer on ebay. They came with ceramic pads too for about 120 bucks shipped. I just installed them today and they work like a dream. You might want to look into a similar setup. I know that the front calipers on mine (88 Jag) are a four piston design while the older ones are 3 piston ( I am assuming). You might look at upgrading to a 4 piston if you dont already them. That would be my guess.
To be honest I am kinda a Mustang guy. My first was a 79 and my mom has an 88 Jag Convert (then I found my 88). Never thought of using a Jag setup in a Cobra kit, looks like it should work really well. Hope this helps you out.
xjrjag
09-24-2015 10:08 PM
