In need of brake help!
Old Oct 8, 2009 | 03:20 PM
m0t0rm0uth's Avatar
Hi James. I'm new to the forums, also...as well as being a first time Jag owner.
I have a 76 XJ12, and a Haynes manual. They have the same brake setup. I will try my best to answer your questions, although I can't promise anything.
I don't know what you have tried, nor what your exact problem is. Can you give a little bit more info on it "just seems like it doesn't want to stop." Here is a section from my Haynes manual on the brake system failing (fault diagnosis):
Pedal travels almost to floor before brakes operate -
- Brake fluid level too low
- Caliper leaking
- Master cylinder leaking (bubbles in master cylinder fluid)
- Brake flex hose leaking
- Brake line fractured
- Brake system unions loose
- Pad linings over 75% worn
Brake pedal feels springy
- New pads not yet bedded in
- Brake discs badly worn or craked
- Master cylinder securing nuts loose
Brake pedal feels spongy and soggy
- Caliper leaking
- Master cylinder leaking (bubbles in master cylinder reservoir)
- Brake pipe line or flex hose leaking
- Unions in brake system loose
Excessive effort required to brake car
- Pad lining worn badly
- New pads recently fitted - not yet bedded-in
- Harder pads fitted than standard causing increase in pedal pressure
- Pads or discs contaminated with oil, grease or hydraulic fluid
- Servo unit inoperative or faulty
Brakes uneven and pull to one side
- Pads or discs contaminated with oil, grease, or hydrolic fluid
- Tire pressures unequal
- Brake caliper loose
- Brake pads fitted incorrectly
- Different types of pads fitted at each wheel
- Anchorages for front or rear suspension loose
- Brakes discs badly worn, cracked, or distorted
Brakes tend to bind, drag, or lock-on
- Air in hydraulic system
- Caliper pistons seized
- Handbrake cables too tight
- Fault in servo unit
After typing all that out, I'd first check your vacuum lines. The brake system is connected to the vacuum system.
Old Oct 8, 2009 | 05:34 PM
m0t0rm0uth's Avatar
Check the section above for EXCESSIVE EFFORT. Where do you live?
Old Nov 10, 2009 | 09:21 PM
redjag8841g's Avatar
I know that you are looking for the best parts possible, but I just picked up a set of drilled and slotted rotors from a dealer on ebay. They came with ceramic pads too for about 120 bucks shipped. I just installed them today and they work like a dream. You might want to look into a similar setup. I know that the front calipers on mine (88 Jag) are a four piston design while the older ones are 3 piston ( I am assuming). You might look at upgrading to a 4 piston if you dont already them. That would be my guess.
To be honest I am kinda a Mustang guy. My first was a 79 and my mom has an 88 Jag Convert (then I found my 88). Never thought of using a Jag setup in a Cobra kit, looks like it should work really well. Hope this helps you out.
jdzubas
Oct 4, 2015 09:14 AM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
Jefro
Sep 15, 2015 01:44 PM
