Airbag yellow light turns on
Hi.
My 2007 XK, ocasionally, turns on the yellow light of the airbags. At the next day, the light might work as it should, until in one or two more days, the light comes on again.
Any tips before taking it to the official Jaguar service?}
Thank you
PS, I haven't seen any blinking; my XK has only one yellow light in the dashboard for all airbags.
Thank you
I've moved your question from General Tech Help to XK/XKR forum. Members here with the same model will be able to help.
As Guy said, the first thing to consider is the age of your battery. When the battery gets old & cannot hold a good charge, you will start to see strange 'faults' that come & go. In most cases, there is no real fault, it's just that the module that controls the sensors has not started up properly because the voltage was low. After you drive the car, the battery is charged, so the light goes away; if you leave the car for a few days, the battery gets low, and the light comes on again.
Thank you all for your comments.
It could be the battery. I still have the original one, from 2007, and don't use this car frecuently, so the battery can be low. I will check this.
A new battery should be bought on a Jaguar dealer, or can I buy any brand battery with the same especifications that fits the place? A friend with a BMW, bought a new battery that did not work correctly, and had to buy another one on a BMW dealer.
The fault ocurred with an empty passengers seat.
Thank you, again.
Thank you, again.
