center dash vent removal
Old 06-20-2012, 11:09 AM
Dlee's Avatar
Genius Gordo!
Old 09-30-2014, 04:07 AM
MikeyB10's Avatar
I had the same problem with the plastic runners on my front air vent. After reading this forum I decided to replace the unit instead of try and fix them. I may use the fishing line and pen insert idea on the one I pulled out, as a spare.
I just wanted to mention my own experience doing the change over as it didt run as smoothly as I had hoped. Firstly those "spring clips" weren't as easily praised off as I had hoped and I managed to snap a couple of them in the process. Also after I had slid the vent unit out from the dash, I wasn't able to access the plug further down the loom and disconnect it from the car.
I weighed up the options of dissembling the dash to access it or cutting the wires to the broken unit and splicing the new unit in its place. I feel like a bit of a hack, but went with the later. After this was done the new unit slid into place with out a problem and the wood trim snugly fitted back on. Because of the missing spring clips I placed a drop of selastic on the anchor points.
Old 05-22-2017, 03:51 PM
ednaiken's Avatar
Help please! I managed to get the vent assembly out but I am having a hard time trying to separate the back end with the main flaps from the vent section. Wondering if the hot SC summers have welded the plastic half's together?
Old 05-22-2017, 04:01 PM
michaelh's Avatar
Received 2,291 Likes on 1,503 Posts
The intakes are plastic-welded to the main body. You will need to make a cut between the retaining clips to separate them:
https://www.jaguarforums.com/forum/x...7/#post1678037
HTH,
Mike
Old 05-22-2017, 04:04 PM
ednaiken's Avatar
OK thanks!
Jpav27
07-31-2022 06:43 AM
jehart49
09-12-2015 05:36 PM
mrplow58
09-09-2015 11:27 AM
RedRider48
09-07-2015 09:41 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: center dash vent removal
