Convertible top rubber seal replacement?
Old 03-01-2011, 12:06 PM
jagosaurus's Avatar
Question Convertible top rubber seal replacement?
The rubber seals on the driver side are crooked, going to a car wash I actually got washed too Wind noise is also a problem.
I went to John's Jaguar in SF, but he doesn't do that kind of work, are there any upholstry shops that'll be up to the task? Or can I get replacements and do it myself without too much difficulty (somehow doubt that it's trivial).
Cheers!
Old 03-01-2011, 04:46 PM
RCSign's Avatar
Jagosaurus
If it's the weatherstrip on the windshield pillar it actually is a easy replacement I believe two screws top and bottom and plastic snaps, been a year since I installed it. It cost around $140.00 new.
Doug
2001 XKR Silverstone
jagosaurus (03-02-2011)
Old 03-01-2011, 06:33 PM
hlgeorge's Avatar
I had to replace the rubber seal over the right rear window. Very easy.
Old 03-01-2011, 06:37 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
My driver side front weather strip got turned under for some time before I noticed it. It was a mess. I got the part number and prepared to order a replacement . . . whoa ! ! ! ! them things are $140 . . . each.
Pulled it off, a easy effort and inspected the damage. It was split in several places and deformed. I got out the super glue which works well on that type of rubber. Carefully using super glue, a dowel as a form, some wax paper and some black RTV sealant got it back into form and function. Used a little RTV to glue the piece back down.
Been in place and functional for some months.
Immediately spent the $140 on another car project.
Tight Wad Tom
The following 4 users liked this post by test point:
jagosaurus (03-02-2011), OregonJag (03-01-2011), rcktmn (05-06-2013), Reverend Sam (03-01-2011)
Old 03-01-2011, 09:47 PM
Reverend Sam's Avatar
Received 1,259 Likes on 564 Posts
Tight Wad Tom
Now THAT'S my kind of repair!
Old 03-01-2011, 09:58 PM
OregonJag's Avatar
<snip> Been in place and functional for some months.
Tight Wad Tom
I'm putting that one in The File.
Mike
Old 03-01-2011, 10:14 PM
WhiteXKR's Avatar
Received 2,982 Likes on 2,123 Posts
Wink
Gee, is this the XK8 forum or Hints from Heloise ?
Old 03-02-2011, 01:14 AM
jagosaurus's Avatar
It's the wheaterstripping above the main (not quarter) windows (not the windshield).. not a 100% with the nomenclature here
Old 03-02-2011, 01:24 AM
jagosaurus's Avatar
test point - how did you reshape it? Did you keep it "wrapped" in the dowel? Why did you need wax paper?
Old 03-02-2011, 04:53 AM
test point's Avatar
I think we are both talking about the weather stripping that the door window slides into at the top.
I used the dowel as a form to mold the sides of the rubber around. Wrapped it in waxed paper since super glue and RTV doesn't stick to the wax. After carefully gluing it back to its original shape, at least as much as possible, taped it around the dowel overnight. Looks as new, no leaks.
Heloise
jagosaurus (03-03-2011)
Old 03-02-2011, 05:31 PM
hlgeorge's Avatar
Wish I could have done that! The seal on mine was just torn off in spots. Had to replace it. It was about 16" long and cost $112.
Old 03-03-2011, 06:29 PM
Stratohammer's Avatar
All of my seals look great, but I'm never going through the carwash again. I thought I could just dash through for a quick spritz. I got spritzed alright! There was water coming in that car from places I didn't even know it had. It does fine in the rain, except for the part where you roll the window down and the gutter dumps right on your leg.
Old 03-03-2011, 07:42 PM
test point's Avatar
Quick . . . run out and see if your third brake light cover is still there!
Several have lost the cover due to the high power air blower at the end of a auto wash.
Old 05-16-2012, 09:26 AM
aregg's Avatar
Where do you guys find prices like $114 and $140? I am told it is $242.85 discounted.
I would like not to pay the additional $100 if I can.
Old 05-16-2012, 09:56 AM
hypoluxo's Avatar
I need to replace the weatherstripping above my front passenger window as it has started to deteriorate. I would love to know of any discounted sources for the part.
Old 05-16-2012, 03:31 PM
oldjaglover's Avatar
I know of one. I'll ask for it if you want. Probably about $50-60. Let me know asap.
wcnesta (06-04-2012)
Old 05-16-2012, 03:39 PM
2002XK8Orlando's Avatar
Add me to that list Driver's and passengers need to be replaced
Old 05-16-2012, 04:35 PM
hypoluxo's Avatar
Alright. I'm letting you know. Thanks. This is the weatherstripping on the convertible top that seals to the passenger front window.
Old 05-16-2012, 07:33 PM
You might have some misalignment of your windows. I used to take mine through carwashes while on trips, and never had any leaks (and that was with one seal having a 4" chunk missing from the outer part of it. Now, if you use the type that wash the car with high pressure water nozzles instead of brushes or straps I could see where you might get some blasted through. But I don't get water in when the blowers dry the car, either.
I have requested the seals for hypolux and orlando. Hopefully I'll get a reply before mine are shipped.
Old 05-16-2012, 09:09 PM
hypoluxo's Avatar
Thanks for the help. Let me know how you would like to handle payment.
Quick Reply: Convertible top rubber seal replacement?
