Upper Ball Joint stuck
Old 03-21-2022, 04:38 PM
David Dougherty's Avatar
Default Upper Ball Joint stuck
I am using the above tool which is what the workshop manual advises. And it will not budge. I am using so much pressure and so far nothing. I was at the point of using a breaker bar but stopped short in fear of breaking something. I have given up for the day but am soaking it in penetrating fluid and will let it sit over night. I have hammered it some but not easy to get a swing at. Not really a good place to try a propane torch. Help!!!!
Old 03-21-2022, 06:00 PM
cjd777's Avatar
Received 1,323 Likes on 735 Posts
Use two hammers and try to time the hit on each side of the A arm.at the ball joint position.
Last resort, buy a hammer air tool, leave the nut on and give it all you got.
If it's worn really bad, it's not hitting on a solid base inside the shell.
The following 2 users liked this post by cjd777:
PKWise (03-23-2022), RJ237 (03-21-2022)
Old 03-21-2022, 06:44 PM
Rivguy's Avatar
Can you get a pickle fork in the joint?
Old 03-21-2022, 09:16 PM
Default Will Give it a shot
The ball joint is good so I would like to save it. If the pentrating oil fails then time to break out the hammers and bang away. Using a pickle fork would be a last resort as having used them in the past the ball joint seal seems to always be ruined.
Old 03-21-2022, 09:30 PM
Johnken's Avatar
Received 1,808 Likes on 1,115 Posts
David this brings back memories. I had to use a p fork, also learned the difference between good ones and the autozone rental one.
I posted comparisons photo of the 2 back then. If interested search under my name, I created the thread. Mate the tool you pictured was destroyed long before I got to the p forks to finish the job.
IME you're maybe worrying too much about scaring the boot. But your call. You know what? I'll find the photos stand by.
John
Old 03-21-2022, 09:37 PM
Johnken's Avatar
David, here is some info about my battles with that same ball joint. If you go with pickle fork, see photos. There was a world of difference between the Snap On fork i borrowed from my mechanic and the nearly useless one from auto zone.
https://www.jaguarforums.com/forum/x...highlight=Fork
John
David Dougherty (03-22-2022)
Old 03-22-2022, 07:32 AM
STLTHMSTA's Avatar
You may have to sacrifice the ball joint to get the job completed. 2 steps back for 3 steps forward. I understand were your coming from but you can't always get it to go you way. Good luck, TM
Johnken (03-22-2022)
bamforp
03-14-2024 03:47 AM
Johnken
09-09-2017 08:31 AM
13was13
05-16-2015 07:44 AM
JagScott
04-12-2013 05:05 PM
Goldlion
01-02-2013 04:07 PM
Quick Reply: Upper Ball Joint stuck
