Halfshaft Ujoints
Old 03-11-2010, 09:23 AM
oldmots's Avatar
Default Halfshaft Ujoints
Just occured to me, do the u-joints in the rear of the 06 models need lubrication? I don't see it on the schedule but I have never looked.
Old 03-11-2010, 09:26 AM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Take it from one that knows. All my u-joints had a fitting for lubrication and they were dry as a bone on my car. I had to replace 2 of them.
Old 03-11-2010, 09:39 AM
oldmots's Avatar
Ouch! I guess I'd better get under there!
Old 03-11-2010, 12:07 PM
Gus's Avatar
Gus
Gus is offline
How is the fishing in the bay?
Old 03-11-2010, 03:41 PM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
Certainly all the older Jaguars XJs 1,2, & 3 etc with UJs had grease nipples, but I am not sure about the modern cars. Sometimes there is a plug to allow a grease nipple to be screwed in, but some UJs have nothing.
Old 03-11-2010, 03:54 PM
Gus's Avatar
Gus
Gus is offline
All of mine were fitted with the nipples. If you do not have them any good parts store will have them.
Old 03-11-2010, 07:19 PM
PeteO's Avatar
My 2000 XK8 and my 2006 XKR are both fitted with them.
Pete O. Vero Beach,Fl.
Old 03-12-2010, 07:12 AM
GreenJewel's Avatar
I grease mine when I change my oil and filter.
Old 03-13-2010, 03:25 PM
chazaroo's Avatar
Pete,
Did yours come with the car or were the fittings add ons?
Old 03-14-2010, 09:53 AM
PeteO's Avatar
Chaz, Both cars came fitted. The XK8 I bought new and the fittings had plastic caps on them.
Pete
Old 03-14-2010, 11:31 AM
chazaroo's Avatar
Do you know if this is something the dealer does in the course of an oil change?
Old 03-14-2010, 11:36 AM
avos's Avatar
Received 1,063 Likes on 759 Posts
It is on all classic XK8/Rs (1996-2006), and you need to grease them every 10Kmiles, so each service.
Old 03-14-2010, 11:57 AM
Gus's Avatar
Gus
Gus is offline
Running them dry was a costly mistake.
Old 03-14-2010, 11:59 AM
chazaroo's Avatar
How Costly?
Old 03-14-2010, 05:44 PM
Gus's Avatar
Gus
Gus is offline
Well I did not need to sell the first born to pay for it. I guess what I was trying to saying is that a little grease will go a long way in preventative maintenance. It was just a matter of having both changed on the same side.
Old 03-14-2010, 06:48 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
no idea where these joints are...looked in the JTIS, couldn't find them.
I'd like to have my lubed appropriately next time its in to get an oil change.
Any diagrams, pics?
Old 03-14-2010, 07:30 PM
Gus's Avatar
Gus
Gus is offline
Matt,
They are on the drive shafts from the rearend to your wheels. You have two universals on each side and you have I think 2 on your drive shaft from the trans to the rearend
Old 03-15-2010, 12:57 PM
daddyo007's Avatar
What is the grease of choice for these u-joints?
I was under there a month ago and briefly looked for fittings, (just bored), but evidently did not look very hard.
Old 03-15-2010, 01:03 PM
chazaroo's Avatar
If properly maintained, how long are the U-joints good for... 60K, 100K or is it a number of years?
Old 03-15-2010, 01:48 PM
DavidB's Avatar
The u-joints very rarely fail, as long as they're greased.
If you're looking for weak points in the driveline, the differential, the rubber isolation ring in the driveshaft, and the driveshaft center bearing fail more often than the u-joints.
TTYL
David
Quick Reply: Halfshaft Ujoints
