long list of codes..HELP!!!
1999 xk8...car has been parked for about 8 months...got in car the other day and started it up...would barely moved forward..not slipping but would barely pull..shift kinda hard into reverse but moves fine...warnings on dash are...check engine light,restricted performance,transmission fault,traction control and stability control warnings come randomly...i had problems with misfire and rough idle before being parked but not the transmission fault...the list of faults are as follows:PO300 mod..1 random/multiple cylinder misfire..2 PO304 cylinder 4 misfire..3 P1316 manufacturer control ignition system or misfire..4 PO121 tps/pedal position sensor A ckt range/perf..5 P1396 mod $11 manufacturer control ignition system or misfire..6 P1643 mod $11 manufacturer control aux inputs aux outputs..7 P1646 mod $11 manufacturer control aux inputs aux outputs..8 P1000 pd mod $11 manufacturer control fuel/air metering aux emissions controls..9 P1396 pd maufactuer control ignition system or misfire..10 P1643 pd manufacturer control aux inputs aux outputs..11 P1646 pd mod $11 manufactuer control aux inputs aux outputs...please someone,anyone help..thanks
Before you get too deep into panic or diagnosis, try two things-
1) a hard reset of the car's electronics- sometimes weird things can happen with the electrics when the car's been sitting for extended periods.
2) check your battery for full voltage. Again, when the voltage drops (as it probably has), the electronics can get very wonky and throw out all kinds of messages.
HARD RESET PROCEDURE:
1. Ignition OFF.
2. Disconnect the negative terminal of the battery.
3. Turn key to ignition ON position.
4. Touch disconnected NEGATIVE terminal of battery to the still-connected POSITIVE terminal for 15 seconds or so.
4. Turn ignition back OFF.
5. Reconnect NEGATIVE terminal to battery.
Then start her up and see if things are better. But as above, you need to make sure your battery is at FULL STRENGTH.
Note that anytime you disconnect the battery, you must reprogram the windows. With the doors closed, raise each window to the top and continue to hold button until you hear a faint "click," about an additional 3 seconds. Then lower each window to the bottom and continue to hold the button until you hear the same "click." Voila, you've reprogrammed the windows.
1. Ignition OFF.
cool..where abouts you at in greenville?i live near riverside high school off hyw 14..although im not willing to sink much more money into this thing im more than willing to compensate if you may be able to help with any of this..my main concern now is the trans fault..if that can be resolved it will be drivable..thanks scott
Received 6,253 Likes
That is marginal for these cars. You should at least charge it, if not replace it. Then reset the codes and see which ones return.
Also, you should inspect under the car a for a possible transmission fluid leak. Unfortunately there is no dipstick, so the fluid level is not easily checked.
Check your throttle plug jaguar throttle body plug Clean it and reinstall and see what takes place. Are you sure you had a P0121?
