Antenna Switch Mod - Need a different power source
Old 01-05-2017, 05:47 PM
rothwell's Avatar
Received 1,252 Likes on 687 Posts
Default Antenna Switch Mod - Need a different power source
I have been waiting to do the antenna switch mod until I found a switch I liked. Finally found one that I think works well. It has a lighted indicator when enabled and a separate lighted caption.
So I know where to insert the switch since that is well documented here. And that power I can use for the indicator light.
What I need to know is where to find a good source of power that is connected to the dash lights so the button will illuminate only when lights are on and will respect the dimming as well.
Can anybody point me to such a power source?
Ungn (01-07-2017)
Old 01-05-2017, 09:14 PM
grantorino62's Avatar
Maybe the green ring illumination around the lighter socket? The lighter is not powered, key off but I think the illumination ring around the socket is on the same circuit as the dash illumination. Educated guess on my part.
rothwell (01-05-2017)
Old 01-05-2017, 10:30 PM
rothwell's Avatar
I forgot about the stuff under the popup that is lighted. That should work great. Thanks for the tip!
Old 01-05-2017, 10:59 PM
Jandreu's Avatar
So where did you source that fancy switch?
Old 01-06-2017, 09:00 AM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
rothwell (01-06-2017)
Old 01-06-2017, 09:42 AM
rothwell's Avatar
It is used in newer Seneca RVs and Freightliner trucks like this.
I got mine on ebay for under $10. Seller has a lot of them.
NEW FREIGHTLINER AERIAL PWR A06-47581-050 SWITCH "NO BOX" AMERICAN LAFRANCE | eBay
Jandreu (01-07-2017)
Old 01-06-2017, 01:23 PM
Great info, thanks! But why so many connections? Do you have any info on what pin does what.
Old 01-07-2017, 07:39 PM
rothwell's Avatar
Today I figured out how the switch connections work. I only need 4 of the pins the rest are going unused.
Tomorrow I plan to install it and follow with a write up and pics.
Old 01-14-2017, 05:59 PM
wymjym's Avatar
I purchased this switch and it is larger than I care for. Since I had already installed a smaller switch if anyone wants this one, let know and I'll mail it to you.
wj
Old 01-14-2017, 07:17 PM
Ungn's Avatar
What are the pins on the switch that illuminate the words?
Old 01-15-2017, 07:33 PM
rothwell's Avatar
I posted a write up in my ongoing thread.
https://www.jaguarforums.com/forum/x...7/#post1603029
Ungn (01-15-2017)
Old 01-15-2017, 08:57 PM
Ungn's Avatar
Thanks Rothwell!.
I think I tried every possible combination to get the switch to light except the pin adjacent to the ground. I mistakenly assumed it was ground, too.
When hooking up the antenna wires, the wire from the head unit needs to go to the "plug nearest "the gap" and the plug going "to the antenna" needs to plug in the middle between of the the three plugs or the "on" light will stay on.
Amp draw of the "on light" and aerial power illumination is only .01 amps
Old 01-15-2017, 09:52 PM
rothwell's Avatar
Originally Posted by Ungn
Thanks Rothwell!.
I did not notice the "always on" possibility of the indicator light. I must have gotten lucky when I plugged them in.
