Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
2004 X-type sirus power install.
Old Nov 24, 2009 | 06:01 PM
sidewalkman's Avatar
Honestly, there is no real advantage to getting the piece that plugs between the radio and the antenna. It is still FM modulated.
But if you decide to go that wat you can splice into any hot wire running off the acc curcuit. There are 2 wires going into the adaptor, 1 hot 1 ground, so wire accordingly. There is a mounting kit available that goes on the right side of the fascia too. Then run all the wires in behind the radio when you have it out and it looks pretty clean.
For a super clean install with crystal clear sound get the ACM. Costs around 300.00 but gives you USB, Aux and ipod connectivity and goes in the CD stacker curcuit. That way you are directly wired in with fiber and no FM modulation issues.
H20boy
Dec 24, 2024 03:23 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
texaspete
Sep 10, 2015 08:34 AM
Numwen
Sep 6, 2015 12:30 AM
