Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Audio Help
Old May 30, 2011 | 01:15 AM
southernjag's Avatar
Default Audio Help
Alright, I am now sold on going aftermarket, but to get the setup I want it might take a little time. To use my stock system until that time comes I am hoping someone can help me figure out what the heck is wrong with my current system. And yes, I have used the search engine and cannot find anything that has worked. There are 2 seperate problems. I know there are more audio savy people then I.
Problem #1.
I have seen a thread on this issue, but it just seemed to answer no questions. My in dash cd player doesnt work. I try to insert a cd and it will go half way in and not pick insert it into the player. Also, when I press the cd button it reads cd error.
Problem #2.
Cd Changer. I was going to let the 1st problem slide then I relized there was problem #2. The changer has power to it as it will eject the cassette, but when I press the CDC button NOTHING HAPPENS. I took it apart and checked the platic gears and made sure they were mated and put it back together and nothing. Still has power just no playing or picking up the cds or playing them either.
ANY help is appreciated AND thank you in advance.
Old May 30, 2011 | 09:42 PM
phd12volt's Avatar
sounds to me like the carriage in the headunit is toast
problem #2, make sure the cd's arent upside down. i have had people do that believe it or not
Old May 31, 2011 | 07:12 AM
Well, I was afraid the head unit is shot. Yes, the cds are put in with the label facing up and are in right side up. Thanks for the help 12volt.
MrWhite
19
Jun 14, 2022 07:49 PM
King Charles
Oct 16, 2015 01:25 AM
sdelliott58
Sep 28, 2015 11:21 PM
Rocky15
Sep 28, 2015 04:59 PM
