Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Jaguar XF - UK import into New Zealand
Old Jun 9, 2013 | 04:22 PM
luca2020's Avatar
Default Jaguar XF - UK import into New Zealand
Hi guys,
I'm looking into importing a Jaguar XF from the UK into New Zealand, importing side of things is fine, but my questions are around the electronics.
How can I make the SatNav use NZ maps?
Does the UK have the same radio frequency range as NZ?
Can I change the miles to KMs?
Many thanks
Luke
Old Jun 15, 2013 | 04:31 AM
u102768's Avatar
You don't mention what model year XF you are importing. If it has a hard drive nav system you will need to get a dealer involved. If it has a DVD you can buy one from here:
Jaguar Australia Map Update - In-car GPS Navigation Upgrade for Australia and New Zealand - powered by Whereis® maps
The radio frequencies are pretty similar. I brought my 98 XJR with me from the UK and was able to pick up all the main radio stations. DAB might be a problem though.
I assume the UK speedo has both miles and km's on it already and you can switch the trip meter and odometer using the touch screen.
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
