Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
No sound from premium Alphine stereo??
Old Jul 9, 2009 | 04:33 PM
Thermo's Avatar
Veteran: Navy
Rodneyat, check fuse F26 (30 amp fuse) in the rear power distribution box. That is the fuse for the amplifier. But, if that fuse is good, then you are more than likely looking at a failed amplifier. You can verify that the amp is getting power by checking pins #3 and #9 to the connector on the amplifier. So, as long as you have 12 VDC there, then all the power input is good and leads to a bad amp.
if you have more questions, just ask.
Old Jul 9, 2009 | 04:39 PM
H20boy's Avatar
Did you do anything just prior to it going quiet...or was it a 'turned it on, and nada'?
2001 White XJ8
Feb 25, 2021 05:02 PM
mbergen
Oct 23, 2019 10:26 PM
42Ajd
Dec 30, 2015 09:45 AM
42Ajd
Sep 21, 2015 07:37 PM
