Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
now the hard part
Old Nov 19, 2009 | 06:52 PM
IrishXtype's Avatar
Default now the hard part
I just got my starter system upgrade.Autobahn1200w kicker amp.and kenwood headunit..no screen or navi..but bluetooth and all that other crud.I need to have it installed and have been reading about custom faceplates,do I need one for a reg deck as well.The guy at best buy told me the could install all my stuff, price is reasonable but im worried about quality.I am thinking they will just frankenstien it in.As well do I need a special wiring harness and how much and where can i find it.Theres a lot of questions in here so thanx for any help..
Old Nov 19, 2009 | 07:05 PM
Thermo's Avatar
Veteran: Navy
Irish, as for the kit to mount the radio in the dash, you will need to check out the Mina website (if I remember right). They are about the only one that I know of that has the correct harness. I know I went into Best Buy just this week asking about stereo stuff and they told me that they can't get the wiring harness to adapt to the factory harness. So, more than likely, they would end up cutting your factory plug off and wiring the radio directly to the car. Not the best of choices. If you do go that way, can I have the old plug?
As for the face plate, I would ask them exactly how they plan on installing the radio in the dash. Do they have the correct face plate that will accept a single DIN radio for a Jag (I doubt it as they don't carry stuff for the Jag), or are they going to mount the radio in the dash using plumbers tape and then simply cut a piece of plastic to fill the space that is left. Again, if you look on the Mina site, they have the radio mounting kit for what you need. IF you lived close to me, I would tell you to come on over and we would install the stereo right in my drive way. That way you can see what is going on and then things can be tweaked to be exactly how you want it. But, it is a bit far to be travelling for a simple stereo install.
Personally, if you are getting a stereo installed, spend the extra few bucks and have a stereo shop that does higher end stuff do the job. You will be rewarded with a much more professional job and something that is done properly. The big thing is to ask them specifically (even get it in writing) that they WILL!!! use a wiring harness to tap into the factory wiring and use a mounting kit, not simply cut a piece of plastic to fill the gap. You find a shop that will put it in writing, odds are you will get what you are after.
Old Nov 19, 2009 | 07:51 PM
IrishXtype's Avatar
WHEN I CHECK THE MINA GALLERY..no section for audio...am I blind or do you have the wrong site.IS it called an iso harness.and about 60 bucks cdn.Does anyone have a part number,or a brand name or something.
Old Nov 19, 2009 | 09:30 PM
Thermo's Avatar
Veteran: Navy
Irish, check out autotoys.com. They have the radio kit for $60 (USD) and it is compatible with a single DIN radio (you get a storage bin for either under or over the radio). http://www.installer-parts.com also has the kit for $37 (USD). The part number is 99-9500. It is made by Metra.
As for the wiring harness, I am not finding any. Any site that has a listing for it says that it is not available at this moment. I will see what i can find. Hopefully someone else will have a good link for you.
Old Nov 25, 2009 | 02:02 PM
sidewalkman's Avatar
I think the same place you suggested for the face plate has a wiring kit. I wouldn't get BB to install it though, they will frankenstien it in, unless they actually have a good installer and not a 10.00 per hour guy who just follows a wiring diagram. You should attempt it yourself, I've done a few and always get more satisfaction out of the finished product.
Old Nov 26, 2009 | 12:59 PM
IrishXtype's Avatar
when i called about the wiring harness they told me the part didnt exsist...I guess they put out the catalog before the parts huh.The guy at my audio shop told me he could still splice into the harness ...that doesnt seem like the best idea...Anyone have luck actually geting a hold of this harness of mystery
Old Nov 28, 2009 | 05:23 PM
I saw it on ebay last week, same as the fascia, and from a different company than the one found here. Dhould have bookmarked it because now it's not there.
Old Nov 29, 2009 | 12:38 PM
IrishXtype's Avatar
Sheite..I'll have to check out ebay...
Old Nov 30, 2009 | 02:25 AM
phd12volt's Avatar
as a side option, i have a few friends up your way that would do a cleaner job than say 98% of any best buy's could. I do have some people that work for best buy that are excellent installers, however they are few and far between. let me a generalized area of toronto and ill get you in touch with someone there. feel free to PM me and ill see if i can get someone to take care of your baby.
AlexSaltLife
Jan 23, 2023 10:41 AM
Scott B
Oct 24, 2015 01:29 PM
Dicque
Sep 19, 2015 12:53 PM
EZDriver
Sep 8, 2015 09:25 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
