Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
only get sound from tweeters
Old Nov 16, 2007 | 01:14 PM
BuckMR2's Avatar
Default RE: only get sound from tweeters
The amp is under the rear parcel shelf on some models.
Old Mar 18, 2008 | 10:20 PM
Guatejag's Avatar
Same in S type? How do you get to it?
Old Mar 21, 2008 | 08:51 AM
BuckMR2's Avatar
If its an 04- its behind the trim on the LH side of the boot.
If its pre 2004 its in with the subs under the parcel shelf as far as I know.
Old Mar 21, 2008 | 11:09 AM
Guatejag's Avatar
Thanks a lot, Buck! I found thespot but... the amp is missing!! [:@](I bought the car a few months ago...). Any advice on a good cost effective aftermarket amp that fits the spot?
Old Mar 22, 2008 | 05:20 AM
BuckMR2's Avatar
The amp talks to the head unit and other units (speedo etc) via unique fibre optic cabling so it would need to be a Jag Cd amp unless changing the head unit too as far as I know.When I upgraded to the premium system in mine I get an error on the speedo as the amp needs to be coded to the car (security) via a dealer.Other stereo upgrades I read about havent had to do this so I must have been unlucky or the amp I got must have been removed from the donor car while the battery was connected causing the error.Still works though most of the time.Occasionally have to turn ignition off and on if sound stops.Will be getting this fixed hopefully at the X type seminar next Friday or if not will pay £50 at dealer to do it.
Old Mar 22, 2008 | 01:04 PM
Guatejag's Avatar
Great post, Buck, thanks a lot. I guessI'll try to find a used or NOS Jaguar amp (any ideas as to where lo look for?) and do thenew instalation. I'll let you know.
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
Rocky15
Sep 28, 2015 04:59 PM
Long Islander
Sep 27, 2015 03:45 PM
42Ajd
Sep 26, 2015 07:04 PM
