Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
parrot bluetooth help
Old Apr 14, 2011 | 08:11 AM
Jag Breeder's Avatar
Default parrot bluetooth help
Can anyone help with the parrot hook up in a 01 s-type premium system I seen plug and play for the non premium but not premium cab someone help with this
Old Apr 14, 2011 | 09:13 AM
phd12volt's Avatar
which parrot piece?
Old Apr 14, 2011 | 02:39 PM
Parrot ck3200 ls-color
Old Apr 15, 2011 | 09:24 PM
Any advice on this one
Old Apr 18, 2011 | 07:37 PM
phd12volt's Avatar
http://blog.parrot.com/wp-content/up...tion_guide.pdf
From what i see, you will need to cut every speaker wire in the front for this to work correctly, also you will need to mute the factory headunit upon activation.
I can help with this, which factory unit do you have installed?can you take a pic of the front of the radio for me?
Old Apr 18, 2011 | 09:15 PM
aholbro1's Avatar
hmmmm....I think there's also a way to feed the parrot in as an aux input in addition to or in lieu of your cd changer....if you are interested in doing it that way....
No doubt the premium system is making it rough on you, otherwise plug-n-play. Someone on the S-type forum has done a parrot-as-aux but not sure who...
Old Apr 19, 2011 | 12:01 AM
Phd12 I got the premium system the one with the amp
Jagzzz
Aug 8, 2021 02:45 PM
sg997tt
Oct 9, 2015 10:57 PM
Msteiner
Sep 30, 2015 08:36 AM
42Ajd
Sep 26, 2015 07:04 PM
