Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Where to place tweeters on STR
Old Mar 2, 2010 | 10:15 PM
jya's Avatar
jya
Default Where to place tweeters on STR
Anyone have a good idea on where to place the tweeters of a pair of splits, before I start chopping away the door trim?
I dont know if there is a place or panel available like that on the XJ.
The only thing that I can think of is on the leather vertical panel above the armrest, just below the timber trim.
Old Mar 3, 2010 | 09:41 AM
phd12volt's Avatar
if i were you, i would mount them in a custom plate next to the main driver behind the grille, if you did 6" ones there is enough room. If not, you could always redo the A-pillar to house the tweeter. I wouldnt want to cut the door out, personnally. I think replacement A-pillars for our STR are like 30 dollars on ebay. Much cheaper than buying new door panels.
Old Mar 3, 2010 | 01:54 PM
androulakis's Avatar
Behind the Main Grille...
Don't cut up the car.
Old Mar 3, 2010 | 06:26 PM
jya's Avatar
jya
Thanks alot Jason and George!
Your contribution on this site is invaluable.
You blokes are certainly very knowledgeable.
I will follow your advise and leave the leather panel alone and place the tweeters on the base of the A pillar as they appear to fit.
I am using using a pair of JVC 300w 6.5" carbon/kevlar woofers I had lying around and am unable to squeese the tweeters along side.
I must ask your advise as to what you would think would complement these front splits for the rear doors?
Presence
Mar 13, 2016 02:21 PM
Manjag
Oct 1, 2015 05:34 PM
JaguarSV8
Oct 1, 2015 01:58 AM
SoCalJagS
Sep 27, 2015 09:20 AM
