Canada All Canadian members please post here...
Belt Removal Help Advice
Old Jan 17, 2014 | 03:07 PM
Jag-GM's Avatar
Default Belt Removal Help Advice
I need some step by step help and advice on a belt removal. I have attached some pictures of a belt I found deteriorating and I want to replace it before snapping as its begun to tear on the outer edge.
Essential could you explain exactly what it is? where might I find one to purchase (Vancouver area)? and most importantly how do I remove it?
Attached Thumbnails Belt Removal Help Advice-dsc_0441.jpg   Belt Removal Help Advice-dsc_0444.jpg   Belt Removal Help Advice-dsc_0443.jpg   Belt Removal Help Advice-dsc_0442.jpg
Old Jan 21, 2014 | 11:23 AM
Mikey's Avatar
I'm going to guess that this belt drives the A/C compressor. Usually the compressor is held by at least two mounting bolts, one of which can be loosened to allow the compressor to be rotated inwards, giving some slack. Any cars parts store should be able to match the belt if you take the old one with you.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
danke
Mar 3, 2016 10:57 AM
sadepol01
Sep 11, 2015 05:26 AM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
