Canada All Canadian members please post here...
Secondary Timing Chain Tensioners
Old Jul 6, 2014 | 07:19 PM
drpsmith's Avatar
Smile Secondary Timing Chain Tensioners
2001 XKR Phoenix
30k KM
VIN SAJFA42BX1PA22744
have read lots of posts and Internet articles about this issue.
can someone give me some info as to whether or not I need to proceed with a preventive replacement of these troublemakers based on the vin and engine number I have posted.
much appreciated
Old Jul 6, 2014 | 08:03 PM
WhiteXKR's Avatar
Check your driver door jamb placard. If your build date was July 2001 or earlier you have the old tensioners and need to upgrade.
If your build date was August 2001 or later, call your local Jaguar dealer with your VIN and get then to look up your engine number.
If you have an engine number of greater than 0108130000 then you have the new tensioners, if it is less, then you need to upgrade.
All this assuming you have an original engine in your car.
Old Jul 7, 2014 | 08:01 AM
drpsmith's Avatar
thanks
May 2001 Build
Makes my choice easy
I'll be on it this week
Thanks again
Old Jul 8, 2014 | 06:12 AM
Fulton's Avatar
if you replace the secondary tensioners with the zip tie method it only takes about 4 hours at a cost of about $300. It's worth the piece of mind knowing you won't loose an engine.
Old Aug 4, 2014 | 04:06 PM
drpsmith's Avatar
Had the 2ndary tensioners replaced last week $1000 CDN. Good thing I did. Cracks were evident even at 18 k miles. Thanks for the help amigo.
Old Aug 4, 2014 | 04:10 PM
drpsmith's Avatar
Had them done last week. Good thing I did. Cracks evident both sides at 18k miles.
thanks amigo.
RoyLittle0
May 25, 2023 02:38 AM
Jpav27
Jul 31, 2022 06:43 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Bowman
Sep 15, 2015 06:54 AM
Bowman
Sep 3, 2015 03:17 PM
