Engine Bonnet Insulation Cover
Old Sep 23, 2010 | 08:49 AM
stremsjg's Avatar
Default Engine Bonnet Insulation Cover
The insulation cover on the inside of the bonnet ('01 XKR Coupe w/86k miles) is dirty and needs to be cleaned and refreshed. I took a vacuum cleaner to the cover but did not improve the appearance. What do you recommend to clean this cover? Would steam work, like was recommended to clean seat belts?
Old Sep 23, 2010 | 10:23 AM
Innovative Detailing's Avatar
For cleaning the BIC or hood liner, I would either go with the steam method or a light spraying of APC+ followed by a light blast with a pressure washer. Use a blower or compressed air to dry, being careful not to saturate the engine. Some of these liners when showing their age, can deteriorate easily and crumble...so inspect thoroughly before cleaning!!
Old Sep 23, 2010 | 11:36 AM
stremsjg's Avatar
By APC do you mean All Purpose Cleaner? What cleaner do you recommend?
Would you recommend a carpet cleaner followed by blowing the liner to dry?
I plan on trying this over the weekend and will report the results. The alternative is to purchase a new liner at $200, so I am motivated on the cleaning side.
Old Sep 24, 2010 | 12:05 AM
Meguiar's has a "Detailer Line" it is their All Purpose Cleaner +
Not too sure about carpet cleaner, it may not have the strength of the APC+ formula which is made for automotive applications....
Would love to hear how your project went, please keep us tuned!
Old Sep 24, 2010 | 07:20 AM
stremsjg's Avatar
David, I took your advice and ordered the Mequire's All Purpose Cleaner to use on the cover. Do you dilute this product? I read where other's have used it and used a ratio of 10:1. I'll read the product's instructions but was wondering what you would use to clean the cover after 86k miles. I plan on using the product on the interior carpets as well.
I show the car in the Jaguar Concours Championship class and have attended 4 shows this year with a final showing in Oct. The judges deducted a few points for this dirty cover, thus the inquiry. The car has averaged a score of 99.8 for the last 3 shows.
Old Sep 26, 2010 | 03:22 PM
Great, you will be pleased!.....just make sure you purchased the APC+, they also offer APC.......The APC+ has fabric brightner's and softner's.....and a low PH as well........I use a 5 gallon storage jug and I mix it 1/2 gallon to 4.5 gallon of H2O....
Hopefully at the next show, after this little project you will score a 100!!
Good luck!
Old Dec 23, 2010 | 02:37 PM
Zenman63's Avatar
Be warned they shrink with cleaning if you not careful
My s type shrunk so much it ripped every hole out! a good 50mm.
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
XJsc-guy
Sep 25, 2015 11:09 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
