2016 XE 2.0d — P0299 & P226C after turbo rebuild — still underboost on highway
Hi everyone,
I’m having an ongoing issue with my 2016 Jaguar XE 2.0d (diesel). After a turbo rebuild (removed, bench-tested by a third-party specialist, and reinstalled with adaptation), I’m still getting fault codes P0299 and P226C under certain driving conditions.
Symptoms are:
Has anyone seen similar behaviour after a turbo rebuild on an XE diesel? How did you identify the cause and fix it? Any advice on what to check or how to interpret this would be really appreciated.
Thanks in advance!
Symptoms are:
- Underboost/slow boost response on smooth highway cruising ~80–120 km/h at relatively low RPMs, especially with cruise control enabled.
- Occasional “reduced engine power” message and Check Engine lamp.
- In city driving the car behaves normally.
- Codes clear after restart and sometimes disappear for a day or two.
- Turbo removed and bench-tested — “all OK in factory settings”.
- DPF/soot filter checked.
- EGR cleaned — still no change in symptoms.
Thanks in advance!
Not sure if you have already an ingenium diesel, but earlier 2.2D (by PSA/Ford since y2000) had same issues when there were leak inside of vacuum operated actuator controlling turbo variable vane lever. Worked without issues on city / traffic, but on highway when boost had time to build up >5-10min it light an MIL and entered on restricted performane due incorrect boost value. Next start up all were Ok again.
Adding the winter conditions and water inside the actuator, what froze and melt again by engine temp, made very difficult to pinpoint this issue back then. All different codes were pushed, high/low boost or incorrect air meter / pressure values.
Thank you very much. I’m currently looking for a service station that can do exactly this. Unfortunately, even before the war it was difficult to find such specialists in Kyiv, and now it’s even harder. But I’m still looking.
Thank you for the detailed explanation, that makes a lot of sense. My symptoms are very similar — works fine in the city, but after some time on the highway it goes into restricted performance, and after restart everything is OK again. I’ll definitely take a closer look at the vacuum actuator and possible internal leaks, especially considering moisture and winter conditions. Much appreciated for sharing your experience.
+1
. . . and from "down under" on the opposite end of the world . . . we offer our support for solving your issues of boost and bullies!
Cheers and best wishes,
**Update:**
Got a second opinion from another Jaguar/LR specialist yesterday. They scanned the car and confirmed the same codes (**P0299 and P226C**).
During inspection we found that the actuator installed during the turbo rebuild was a cheap aftermarket (Chinese) unit. The mechanic suspected it might not be controlling the VGT position accurately under steady load.
They removed it and installed a used **original OEM actuator** to test this theory. Everything was adapted and the car now drives normally.
The plan is to drive it for a few days and specifically test the conditions where the fault usually appears: steady highway driving at about **80–120 km/h with low RPM**, often when using cruise control.
If the problem disappears, it would likely confirm that the aftermarket actuator was the cause.
I’ll report back once I have more highway miles and see how it behaves.
Update: We tried replacing the actuator with a used original one (the rebuilt turbo had a Chinese aftermarket actuator installed before). Unfortunately it did not change anything. After about 10 km on the highway using cruise control, the same problem appeared again. At this point the local specialists are suggesting that the next step may be installing a new original turbo.
I will update the thread once there is more progress.
JimC64
Jaguar Press release
May 11, 2015 07:33 PM
