AHB coding
Hi everyone,
I'm trying to activate by CCF the AHB on my E-Pace 2019 (MY2020), with Traffic Sign Recognition and Automatic Emergency braking as original equipment.
I found three channel regarding this optional and I tried different configuration:
1)
446 0x4061 194 Auto High Beam System Status FITTED
446 0x4063 194 Auto High Beam Sensitivity Menu NOT ENABLED
246 0x2427 AHB system AHB+LDW/TSR LDW switch Sensitivity menu active.AHB menu present
Result: TSR and AEB not working, light regarding not front advice working, AHB optional selectable by lever with working light but I didn't tested on street without light
2)
446 0x4061 194 Auto High Beam System Status NOT FITTED
446 0x4063 194 Auto High Beam Sensitivity Menu ENABLED
3)
246 0x2427 AHB system Error condition (as origin)
4)
Result: TSR and AEB OK, AHB optional not selectable by lever and no AHB green light
Did you find a working configuration?
Many thanks
Best regards
Luca
1)
2)
3)
4)
Many thanks
Best regards
Luca
Hi everyone, I'm fighting again with this problem: maybe the codes used are good but I discovered that IPMA must learn the CCF after the modification and mine doesn't work, the messge is "out of range".
Is there someone that has on his owns E-PACE AHB, TSR and LDW fitted? Can you tell me which part number is your IPMA?
thanks!
Luca
thanks!
Luca
