E-Pace 2018 - Onwards
AHB coding
Old Jul 28, 2025 | 01:47 PM
Il Signor Zetec's Avatar
Default AHB coding
Hi everyone,
I'm trying to activate by CCF the AHB on my E-Pace 2019 (MY2020), with Traffic Sign Recognition and Automatic Emergency braking as original equipment.
I found three channel regarding this optional and I tried different configuration:
1)
446 0x4061 194 Auto High Beam System Status FITTED
446 0x4063 194 Auto High Beam Sensitivity Menu NOT ENABLED
246 0x2427 AHB system AHB+LDW/TSR LDW switch Sensitivity menu active.AHB menu present
Result: TSR and AEB not working, light regarding not front advice working, AHB optional selectable by lever with working light but I didn't tested on street without light
2)
446 0x4061 194 Auto High Beam System Status NOT FITTED
446 0x4063 194 Auto High Beam Sensitivity Menu ENABLED
3)
246 0x2427 AHB system Error condition (as origin)
4)
Result: TSR and AEB OK, AHB optional not selectable by lever and no AHB green light
Did you find a working configuration?
Many thanks
Best regards
Luca
Old Jan 29, 2026 | 06:10 PM
Hi everyone, I'm fighting again with this problem: maybe the codes used are good but I discovered that IPMA must learn the CCF after the modification and mine doesn't work, the messge is "out of range".
Is there someone that has on his owns E-PACE AHB, TSR and LDW fitted? Can you tell me which part number is your IPMA?
thanks!
Luca
Themes1
General Tech Help
Oct 13, 2024 09:42 AM
doublekite
Nov 4, 2023 07:20 AM
scousejag
Feb 10, 2023 02:38 PM
swajames
Jun 16, 2015 08:30 AM
sn4p
Jun 19, 2014 11:59 PM
