E-Pace 2018 - Onwards
CCF file modification: how to?
Old Apr 18, 2025 | 07:50 AM
Il Signor Zetec's Avatar
Default CCF file modification: how to?
Hello everyone,
I bought a VXdiag VCX SE interface with pathfinder from VXDIAG shop on aliexpress but I have problems with the helpdesk and with the program itself.
I want to play with my E-Pace MY2020 and change some CCF data.
When I open Pathfinder, the connection to software DFSN doesn't work, but if I go in service => CFF file selection => from main module, the software download a vbf file with my VIN in the directory User\VXdiag\\appdata\local\temp, file that I can open with CCF tool and modify.
Questions:
- Is this file the same as as built?
- Which differences are there?
- Can I put this modified file in the directory User\VXdiag\\appdata\local\temp|SADFA...extracted to permit to Pathfinder to upload as new CCF with Service=> CCF file selection?
I'm a bit confused...thank you!
Luca from Italy
Old Apr 18, 2025 | 05:39 PM
Tech_JLR's Avatar
What are you trying to modify ?
Old Apr 19, 2025 | 03:10 PM
Thank you for your reply, for now I want to activate rear animated turn light, change l/100km in km/l in the cluster (I found, it seems, an address to modify it) and in the future I want to retrofit other optional like blind spot radars...but all depends from the possibility that I have to tune the CCF file
Old Mar 27, 2026 | 05:05 AM
Meanmugga's Avatar
What exactly is CFF?
philwarner
44
Nov 5, 2024 06:29 PM
BLKJAG702
Sep 26, 2020 05:30 PM
meirion1
Jan 31, 2016 10:07 AM
trosty
Aug 12, 2015 10:44 AM
carelm
Feb 8, 2009 02:52 AM
