E-Pace 2018 - Onwards
e Pace rear camera wonky view
Old Oct 17, 2023 | 05:06 AM
Colin Chapman's Avatar
Default e Pace rear camera wonky view
Hi,
My rear camera on my 2018 e Pace is showing a wonky view as per the attached picture.
The camera is physically straight in the casing and I have removed it and put it back just to make sure, so I am guessing this may be a software issue or the internals of the camera have come loose.
The view is showing part of the number plate and the left hand side view (as you look through the rear window).
The yellow tyre markers are straight and move correctly when I turn the wheel.
Does anyone have any suggestions before I look into a new camera?
Thanks in advance. Colin.
Old Oct 17, 2023 | 05:25 AM
dangoesfast's Avatar
I've got a fiver on internals coming loose.. Remove it again, shake the s**t out of it, and see if the angle changes 😂
Old Oct 17, 2023 | 10:55 AM
2018XF25T's Avatar
I believe the rear camera is mis-aligned.
Old Oct 17, 2023 | 01:42 PM
Yes, it definitely is. Do you know how I can fix this?
Old Oct 17, 2023 | 07:54 PM
2018XF25T's Avatar
Have it check to your nearest JLR. According to what I read online, the camera needs to be replaced. But first, check for corrosion in the wiring loom conncting the camera. maybe it's just the connection.
Old Oct 19, 2023 | 02:12 AM
Will do. Thank you.
Bob Hornby
Apr 18, 2021 06:27 AM
Serlock
Apr 15, 2021 05:39 AM
STMPY
Oct 3, 2019 02:25 PM
f_in_seattle
Jan 28, 2015 05:26 PM
