Engine rising in T when turned off
I have a 2020 E-Pace with less then 2000 miles.
Sometimes when I turn the engine off, the temperature rises quite a bit. Last time it did that, 2 hours after the engine was turned off, the hood was so hot that I could barely keep my hand on it. But everything was fine when i parked it and turned it off.
I brought it to the dearlship 3 times already, they change a sensor the first time, but since then, they say it is fine or normal since no error code or lights pop up in the dashboard.
If it was normal, this would happen everytime, right ? It does not.
Don't know if anyone experienced a situation like this - info/advise would help
Thank you
Stephan V
Thank you
Stephan V
Welcome to the forums Stephan,
I've moved your question from General Tech Help to E-Pace forum for advice from members with the same model.
hankycbr
Jan 21, 2011 08:45 AM
