E-Pace 2018 - Onwards
IPMA module
Old Nov 4, 2025 | 02:50 AM
Marion's Avatar
Default IPMA module
Hello,
I have a problem with the IPMA module in my 2019 E-Pace. Using Pathfinder, I started updating the modules one by one, and after updating the powertrain, the IPMA module stopped working. It turns out that it’s not the original one. Someone replaced it earlier, and it has a different VIN. When I try to update it or perform the “replace module” procedure, Pathfinder starts the process but during the “learning CCF” step, it throws an “ out of range” error message and the procedure stops.
Has anyone encountered a similar issue and could possibly help?
Old Nov 17, 2025 | 11:26 AM
RoverJoe's Avatar
Community Influencer
You cannot reprogram the VIN once programmed, so it's looking for a blank value and not finding it, which will make it stop. There is no good option other than replacing the module with a new one that has no VIN programmed, unfortunately.
Sparky565706
Mar 20, 2024 08:50 AM
rande
Dec 17, 2023 03:13 PM
schuess100
Oct 19, 2022 04:37 AM
Tetedampoule
May 18, 2022 04:29 AM
Roc3207
Sep 11, 2017 05:17 PM
