1974 XKE front rotor replacement
I am looking for some technical advice on removing the front rotors on a 1974 Jaguar XKE. The Repair Operation Manual for Jaguar Series III V.12 E Type I have seems to be referring to a different vehicle. The diagram does not match my Hub and rotor. Any help would be greatly appreciated!
Here are pictures of the page in the manual and the actual hub and rotor. I assume the rotor can be replaced by removing the bolts. However, access through the disc shield is extremely limited.
The Series 3 E-Types came with bolt-on pressed steel wheels so the workshop manual shows a hub for these, not the ones for centre-lock wire wheels. However both types of hub are held on with the centre nut.
efleming21
Mar 22, 2010 08:00 PM
