E type ( XK-E ) 1961 - 1975
wiper blade removal
Old Apr 30, 2018 | 01:42 PM
hobexkr175's Avatar
Default wiper blade removal
Can't seem to figure out how remove the blades from the arms. 1969 E-type.
help!
Old May 2, 2018 | 09:39 AM
Dave_Car_Guy's Avatar
If you mean how to remove the rubber blade itself from the metal arm, you don't. You replace the entire metal arm with rubber blade attached (from SMG Barratt, for example). The shaft stays the same. If you want to remove the metal arm from the shaft, you pull outward while pulling up on the release flap. There is a small nub of metal on the shaft that sits inside a recessed cutout in the arm/blade. You have to get those to clear each other to get the arm to pop off. I know that's a pretty vague explanation, but it's my recollection and all I can do without a video!
Alan R
Apr 28, 2018 08:10 PM
Kit1
22
Feb 15, 2015 06:01 PM
chadmc5c
44
Jun 10, 2014 02:47 PM
1995XJ609
Jan 18, 2009 04:38 PM
