E type ( XK-E ) 1961 - 1975
70 Roadster Timing Chain Release
Old Oct 25, 2022 | 07:33 PM
johnrmclean's Avatar
Default 70 Roadster Timing Chain Release
Is there a way to release the tension on the upper timing chain without using the jaguar tool
Old Oct 26, 2022 | 03:39 AM
dibbyandco's Avatar
Put prongs of round nosed pliers into holes of serrated plate and rotate clockwise. First need to knock up the tab washer you see when removing the breather and slacken the bolt. Then depress the spring loaded plunger before trying to rotate.
Old Oct 26, 2022 | 08:33 AM
Thanks!
Old Oct 27, 2022 | 07:25 AM
Jtestrake's Avatar
It can be done with a suitable pair of pliers but the Jaguar tool is fairly inexpensive and works so much better.
Old Oct 27, 2022 | 08:24 AM
Update . It turned out to be very easy to use the pliers method to release the tension. . Lifting the head up off the head bolts (while still in the car) has turned out to be much harder!! 4 hours in alternating a small hydraulic jack from side to side of the head to lift it quarter inch or less at a time.
Old Oct 27, 2022 | 08:47 AM
Coventry Foundation's Avatar
+5 to jtestrake. The proper tool allows a free hand which is necessary on reassembly.
Old Oct 27, 2022 | 08:58 AM
Default Reassembly
Reassembly will be a whole new adventure IF I try that part myself.
Old Oct 27, 2022 | 06:19 PM
Fraser Mitchell's Avatar
It's funny, I've never had a problem getting an XK cylinder head off, but I've only done a 2.4 and a 4.2 litre engine.
Old Oct 27, 2022 | 09:39 PM
Default Free at Last
Free at last .. lots of carbon dating ...penetrating oil pooling in cylinder 4 ....on to stud removal .
Old Oct 28, 2022 | 03:58 AM
dibbyandco's Avatar
I found the head came off my 4.2 long stud ok providing you kept it dead straight and level, otherwise you jammed on the studs
Old Oct 28, 2022 | 08:40 AM
That was part of the problem with the side to side hydraulic jack method. Too much crud for hand work but no way to keep the lifting straight..
CaptnJack
Jul 1, 2021 05:16 PM
George05
Jun 29, 2021 06:51 AM
Cheddarfish
Apr 8, 2021 02:25 PM
TN8Shooter
Sep 30, 2012 09:16 PM
filoli1993
Dec 17, 2010 01:40 AM
