E type ( XK-E ) 1961 - 1975
con rod bearings
Old Aug 2, 2017 | 11:57 AM
JRR705's Avatar
Default con rod bearings
Hi All,
I think I've spun a connecting rod bearing in my '71 E-Type (3.8).
Is it possible to R&R the bearings without removing the engine?
Old Aug 7, 2017 | 02:38 PM
new mexico's Avatar
Default bearings
Originally Posted by JRR705
Hi All,
No problem there, the hardest part is lifting the engine a bit to take off
the pan.
For lifting the engine you will need a railroad tie across the engine and
hook up a chain to lift it to remove the pan.
Then remove the bolts, push the rod with piston up and check and
replace the bearings. Check with clearance with plastic gauge.
Walter
