E type ( XK-E ) 1961 - 1975
Confused about balancing wire wheels
Old Sep 13, 2022 | 05:01 PM
MrVette's Avatar
Default Confused about balancing wire wheels
I bought new tires and wheels. I understand tire shops can mount them but the hubs don't fit on the balancing machines and some sort of adapters are required.
Looking at the various adapters and cones listed by parts suppliers I can't discern what I really need. I've seen cones sold based on mm. But what are they measuring? I've also seen an adapter. Is that all I need to fit on a spin balancer or what?
My wheels are MWS 6" x 15" with the hubs and lacing appropriate for a 1971 4.2.
Old Sep 16, 2022 | 03:01 PM
Coventry Foundation's Avatar
You need a special adaptor or a copy. They are known as a Hoffman adaptor. You need an adaptor that matches the angle on the inside of the wheel so the wheel does not sit on the flat plate.
Old Sep 17, 2022 | 09:49 AM
DaveAllen's Avatar
Here's a page linking mm and hub size. E-Types have the 52mm hub and are 73mm in diameter.
MWS
This page shows how the cones work
MWS
I got my cone adapters here
Wire Wheel Balancing Kit - Fosseway PerformanceFosseway Performance
I haven't actually used the cones because my rough balance on a bubble level worked so well.
HTH, Dave
Old Sep 17, 2022 | 10:10 AM
I came across this https://mossmotoring.com/balancing-w...r-lock-wheels/ it says basically the same thing as the other links but explains it more clearly.
(IMHO)
brkcskn
Feb 25, 2026 12:45 PM
Daniel76
Jun 20, 2018 01:41 PM
marinos90209
Jan 26, 2014 10:15 AM
vpjag
Aug 19, 2013 04:32 PM
malc4d
May 31, 2013 08:57 AM
