E type ( XK-E ) 1961 - 1975
Driven Man 5 Speed Gearbox for E type
Old Nov 11, 2015 | 11:10 AM
nhdazza's Avatar
Default Driven Man 5 Speed Gearbox for E type
Hi has anyone had any experiances of the Driven Man 5 speed gearbox, trying to fit one currently and the bell housing supplied will not fir against the block without the clutch fork having zero movement, running a 9.5 inch clutch, response I have had below
In those instances it is completely acceptable for the installer to grind away a notch in the face of the on the gearbox thus providing more clearance for the clutch fork. Common sense will dictate the correct amount of material to remove.
I paid for a gearbox to fit not engineer!!!
Old Aug 26, 2016 | 07:03 AM
gtjoey's Avatar
What model jag do you have and what engine?
Thanks in advance
GTJOEY1314
Old Aug 26, 2016 | 11:42 AM
nhdazza's Avatar
Thanks in advance
GTJOEY1314
Hi I gave up it was s1 3.8 FHC thanks for replying anyway
Old Aug 27, 2016 | 03:04 PM
vrracing's Avatar
You "gave up" as in sending it back? Did they take it back or charge your 20% for the pleasure of doing business with them? ��
Old Aug 28, 2016 | 01:33 AM
nhdazza's Avatar
Default 5 Speed Gearbox
Hi I had purchased through SNG Barratt in the UK and they gave me a full refund,
Old Aug 29, 2016 | 10:23 AM
vrracing's Avatar
Ah. Very nice!
Old Jul 3, 2023 | 01:37 PM
yorkag's Avatar
Default Driven Man 5 speed conversion
I installed their kit which includes bellhousing. Problem I'm having is starter does not engage flywheel correctly. It is just skimming flywheel teeth. Tyring to get ahold of Driven Man but perhaps extended Holiday is the problem. Would appreciate hearing from others
sasie007
61
Nov 24, 2016 03:13 AM
Unhingd
US Northwest
Feb 16, 2016 03:04 PM
JaguarCar
Nov 11, 2015 09:34 AM
