E type ( XK-E ) 1961 - 1975
Fuel pump config
Old Aug 17, 2015 | 01:36 PM
dougripley's Avatar
Default Fuel pump config
Anyone have a drawing, photo or description of how the fuel pump should be connected on a series II E type, especially the bracket and the fuel pump to the bracket
Old Aug 18, 2015 | 12:16 PM
Mr. Barry's Avatar
I don't have a photo, but the pump is horizontal, with the motor to the rear...It stands on the platform, attached by three rubber-insulated studs...The banjos are also mounted horizontally, with the inlet/outlet pointing to the front of the car.
Hope that makes sense.
Edward
Old Aug 19, 2015 | 08:12 AM
vrracing's Avatar
I just took some pictures of the fuel pump area in my 70 OTS. Maybe these will help.
https://goo.gl/photos/3x9pVR52uizrMe929
https://goo.gl/photos/ySy8VXdrBwVE1Yyp7
https://goo.gl/photos/mrqKv3SUPdzKUQks6
https://goo.gl/photos/skGGBL2LBcUWbsHN8
Good luck,
Jim
Old Aug 19, 2015 | 10:55 AM
Mr. Barry's Avatar
Other than the fuel-line positions, mine is similar...Both of my fuel lines go directly forward.
One, through the bulkhead, and the other curving around the bulkhead, to the tank.
Edward
Old Aug 20, 2015 | 07:20 AM
lowdrag's Avatar
I suggest you look here for the definitive answer. Page 42 gives the exact placement for your S2 pump.
http://sngbarratt.net/catalogue/etyp...%20Low-Res.pdf
Old Aug 20, 2015 | 05:37 PM
dougripley's Avatar
Thank you for the help it has been most beneficial. My car had an after market pump ( not an SU or like) which was connected to the body with one bolt and no pump mounts, I am assuming that the pump is connected to an "L" bracket by a clip and the "L" bracket connected to the body as is shown on xk's diagram.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Kmw
Sep 8, 2015 04:52 PM
Sprayall
Sep 3, 2015 07:49 PM
