E type ( XK-E ) 1961 - 1975
Help 71 v12 no power
Old Dec 10, 2012 | 12:15 PM
ragtop00's Avatar
Default Help 71 v12 no power
I purchased a nice 2 owner 41K mile 71 2+2 auto in Sept and it has been in the shop since. It was stored for 10 years and the gas turned to tar. Here's what the shop has done so far. Removed and cleaned tank and fuel lines, rebuilt carbs, installed new fuel pump, filters and spark plugs. Installed new Reopus H ignition. The car starts and idles but doesn't have enough power to get out of its own way and takes about a mile to get up to about 60mph max (top speed). This is my first Jaguar and I'm beginning to get frustrated. I love the car but it seems that NOBODY in my area knows how to make these run well and be a dependable driving car. Any suggestions would be appreciated.
Mike
Also, on the Corvette forum it is simple to post pics from photobucket. Is it possible to post to this forum?
Old Dec 12, 2012 | 09:10 AM
whattrouble's Avatar
just guessing from here re possibilities.....1. is the advance working on distributor? 2. compression good on all cyliders? 3.fire to all cylinders?
can tell you that my mechanic tried to upgrade my v12 with electronic ignition - i dont remeber precise reasons but as accomplished as he is, he could not make it happen and ended up reinstalling points- after checking the first 3 simple ones, you might try backtracking to original ignition to see if that cures you- nobody likes going backward, but.....
Old Dec 12, 2012 | 08:11 PM
Jagfixer's Avatar
The twelve cylinder engine is a double six. It has two overlapping firing orders. Make sure it is timed to the proper bank, and make sure the wires are installed in the proper order such as 1A, 1B, 2A, 2B and etc. not in that order but should be marked somewhere on covers or in manual. The distributor fly weights due rust and become stiff, converting to electronic is not necessary.
Old Dec 13, 2012 | 09:01 PM
Jagfixer's Avatar
Another thought! The V-12 cap and rotor from aftermarket has been known not to have the correct rotor. The newer OEM has a magnetic( another word) in the rotor and is different than the older ones and will not interchange. Will cause power loss and sometimes a miss.
JWheeler
Nov 22, 2019 08:28 AM
Doug
Feb 27, 2019 01:31 AM
CXJ
Nov 28, 2015 11:41 PM
prettydaim
Sep 10, 2015 04:27 AM
1100me
Sep 7, 2015 06:26 AM
