E type ( XK-E ) 1961 - 1975
Jacking location for rear wheels
Old Nov 4, 2014 | 08:43 AM
Mr. Barry's Avatar
Question Jacking location for rear wheels
I want to jack both rear wheels on the "E" at the same time....What is the best location? I need to be able to turn the wheels.
I have a bridge jack on my 4-post, so I can put it almost anywhere under the car.
Edward
Old Nov 5, 2014 | 08:59 AM
Jagfixer's Avatar
There are trailing arms that come from axle to body in front of tires. You can see the center bolt hanging down thru bushing. You have one on each side. If no exhaust I put piece of wood on jack and raise from center of cage. Be careful when jacking from trailing arms. If rubber mounts are bad it will drop rear to floor.
Old Nov 5, 2014 | 01:43 PM
Mr. Barry's Avatar
Thanks for the suggestion....
I looked at the trailing arm mounts, but decided that I could lift both half-shafts at the same time, from the ends, (with the bridge jack), and it would be properly supported...This seemed to work well....
Turning the wheels with the engine in gear (plugs out),was a whole other problem...Finally used my wood knock-off wrench to do it...Now , on to finding tappet spacers...
Clearance on exhaust side was all over the map!
Edward
Old Nov 6, 2014 | 03:46 PM
Fraser Mitchell's Avatar
You can jack up under the rear subframe with a trolley jack, (I've done this myself in the past), but you need to make sure you use a piece of wood to spread the load on the tie plate where you'll be jacking. Actually, it is quite usual to find this tie plate has been damaged by somebody jacking it without the timber. Usually it is the edge of the tie plate that gets damaged.
RoyLittle0
May 25, 2023 02:38 AM
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
innzane
Sep 2, 2015 10:08 AM
