E type ( XK-E ) 1961 - 1975
Missing vacuum line connection
Old May 26, 2018 | 05:45 PM
dpoznan's Avatar
Default Missing vacuum line connection
I have a 1970 E-type Series II DHC.
In replacing distributor cap, rotor, points & condenser, I noticed that there is no vacuum line connected to the vacuum unit of the distributor. The previous owner had "sleeved" the carb, bypassing the secondary. I guess that is a common modification for performance. Could it have any relevance to the missing vacuum line connection? Where is the connection to the vacuum unit supposed to come from? I see no open line or even a connector on the manifold.
Old May 28, 2018 | 12:12 PM
Mr. Barry's Avatar
Previous owner did you a large favor...If you don't need a "concours" car, then leave the setup alone....The vacuum connection is on the intake manifold, on the end closest to the firewall...Hopefully it is plugged or capped....
Your timing is now by mechanical advance, and should be set around 10 degrees at idle.....(this varies by engine)....
The '70 is the only 4.2 , that had a vacuum "retard", instead of advance...This was to meet the new smog regulations...It ruined performance....Changing back to retard setup will be expensive, if the diaphram in the dizzy is bad (which it probably is), or a different distributor has been installed with no vacuum advance....
My '70's performance improved dramatically, when I removed the retard(ed) setup.
Edward
Old May 28, 2018 | 01:56 PM
dpoznan's Avatar
Edward-
Thanks for the info. I think I will hook up a fake vacuum line for appearances and leave the distrib operating as currently set up. After the ignition rebuild the car performs beautifully.
Dan...
Old May 31, 2018 | 05:21 PM
George Camp's Avatar
There is a chance your car is titled as a 70 but a late 69. If so it would have neither an advance or retard as mentioned.
aquifer
Nov 10, 2015 07:56 AM
Calhale
Aug 24, 2015 12:59 PM
Ericbilt25
Feb 28, 2014 03:33 AM
denraden1
Jun 30, 2013 12:04 AM
martynw
Jun 1, 2011 07:25 PM
