E type ( XK-E ) 1961 - 1975
new type brakes for xke ?
Old Mar 10, 2015 | 04:15 PM
felinecat's Avatar
Default new type brakes for xke ?
Has anybody ever changed XKE's complicated, inefficient, brake activation system from............master cylinder with vacuum valve and slave tandem cylinder and attached vacuum booster and vacuum reservoir...............
To a modern dual master cylinder with a dual diaphragm attached single unit with built in reservoirs....?
This is the way all new Jags are equipped and so are most other cars !
This whole package can be purchased for $250...... Of course it must be matched for the correct size piston volume and for disk front & disk rear
application...........I have built a lot of cars from the ground up and have never seen such an over complicated system, with too many things to go wrong as in the XKE Jaguar brake system !
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
David Thompson
Sep 3, 2015 07:48 PM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
