E type ( XK-E ) 1961 - 1975
Paint Stripper Recommendations
Old Oct 21, 2022 | 05:29 PM
johnrmclean's Avatar
Default Paint Stripper Recommendations
Moving into my 70 Roadster project and need to start considering paint strippers.
Old Oct 22, 2022 | 09:31 AM
Valerie Stabenow's Avatar
Default paint stripper
I stripped my 69 using aircraft stripper. Be sure to protect the floor with heavy duty sheet plastic and change out of whatever shoes you are wearing while doing the work. If you mistakenly get the stripper on your shoes, it will eat house flooring. Using a heat lamp on the area/section that you are working on helps to speed the process. Be sure to wear protective breathing and eyewear. Read and follow the manufacturer's directions and precautions. Dispose of used material safely. Don't keep used cloths, paper, etc that has stripper on it indoors. Put refuse in a fire/flameproof container outside.
Pale340
Dec 16, 2015 09:18 AM
GrahamPhotog
General Tech Help
Sep 6, 2014 01:02 AM
walkman1
Aug 30, 2013 12:18 PM
tmny277
Aug 5, 2012 09:53 AM
Wild Bill
Aug 15, 2011 02:50 PM
