Rear control arms
I've already used all the tools and taken all the bolts out and it won't move at all. Is the rearend putting force down on it? Do I need to jack up the body and they will fall right out? Is there some kind of sequence I need to follow?
These are well known for this. When I replaced mine, I covered the area with anti-seize.
Good Luck....
Let us know it that technique works for you...I ended up having to cut them off with a "Wiz-wheel"...(very carefully!)...After drilling the rubber all around, and dropping away the arm, leaving the cup still attached...One good cut in the cup, then whacked it off with a cold chisel.
Edward
Edward
JimC64
31
Apr 23, 2016 05:32 PM
