E type ( XK-E ) 1961 - 1975
Removing Cylinder Wall Surface Rust
Old Nov 24, 2022 | 06:53 PM
johnrmclean's Avatar
Default Removing Cylinder Wall Surface Rust
So just finished freeing up and removing all my 70 4.2 L pistons . The rust appears surface only but I think I need to do some honing to confirm the condition . Recommendations welcome.
Old Nov 25, 2022 | 06:15 AM
piper 888's Avatar
Mic the cylinder walls after honing them and if there is a lip at the top borrow a ridge reamer so you won't damage the new rings is my two cents worth!
Old Nov 25, 2022 | 09:30 AM
Default Ridge Reamer
Worth a buck at least !! Thanks
Old Nov 25, 2022 | 05:49 PM
Fraser Mitchell's Avatar
When I rebuilt my 4.2 litre around an uncracked block, (another story !), in the early 90s I bought a drill-operated hone specially made for the 4.2 litre engine. It looked like a wire brush with blobs of material on the ends. It cleaned up the bores nicely and the engine ran beautifully afterwards.
Old Nov 25, 2022 | 06:20 PM
I thought about using one of those but I heard on a YouTube from an experienced performance builder he does not recommend those hones unless your sure the cylinders are not tapered as they will only follow the existing cylinder contours which could already be out of whack. If your using a drill mounted hone he recommends the three legged type that have long stones on each leg as they are more likely to keep, or even improve the straightness of the walls.
Old Nov 26, 2022 | 02:00 AM
Bill Mac's Avatar
We used those "wire brushes with blobs" for years for honing aircraft cylinders.
Worked a treat. No problems
asjdhsajhdfj
Jul 25, 2021 10:49 AM
Usmc_Kak
May 14, 2014 01:13 PM
trebor12
UK & Eire
Aug 19, 2012 12:25 PM
Benhamtroll
Oct 25, 2011 12:09 PM
Bubberstone
Dec 10, 2010 12:03 PM
