E type ( XK-E ) 1961 - 1975
Replacing Camshaft cover gasket
Old Apr 5, 2018 | 04:56 PM
dskcis's Avatar
Question Replacing Camshaft cover gasket
Hello!
I need to replace the camshaft cover gasket on my 1966 XKE, and having trouble finding some info, and I'm guessing someone here would know.
1. What amount of torque should I use to tighten the nuts on the camshaft cover?
2. What order should I tighten down the nuts on the camshaft cover, if any?
3. The gasket I purchased says it does not require gasket sealers or a silicone bead, should I trust this? If not, what sealer do you recommend?
Thanks for the help!
Dave
Old Apr 6, 2018 | 09:02 AM
gtjoey's Avatar
Use silicone..........lots and lots of silicone......
GTJOEY1314 6,000 MILES PER YEAR IN MY 66
Old Apr 6, 2018 | 02:24 PM
Fraser Mitchell's Avatar
Hmm, I would have said not to use too much ! I used to use a bit of Hylomar, but silicone was not in common use when I had my XJ6 Series 3. Usually the cover gasket seals OK, but oil leaks out from the securing studs, and also from the half-moon seal at the back of the cambox.
Old Apr 6, 2018 | 09:58 PM
cat_as_trophy's Avatar
+1 Fraser . . . and especially about the special washers & faces of cam covers at studs and domed nuts . . . but then we never used the gaskets and relied on sparing use of Permatex 2 (the magic "blue goo") after first "truing" the mating faces. Washers & nuts referred to were sparingly goo-ed to lower faces, ensuring a faultless seal with minimum torque and no mess.
I can't recall the actual factory spec for tensioning down these cam cover nuts, but I do recall it was very light . . . however, I have seen so many warped covers that I am convinced that most who had been there previously, had no idea either.
Best wishes,
Ken
Old Apr 8, 2018 | 09:50 AM
new mexico's Avatar
Default cover gaskets
Originally Posted by dskcis
Hello!
Dave
Dave!
I always cleaned up my washers and flattened them with a file, checked the
cover for flatness against the head.
I used a small amount of red silicone adhesive seater on both sides and
carefully the gasket and cover.
Tightened the nuts from the middle outward a small amount at a time the
nuts are tight against the cover, a little more then just touching.
Let the silicone do its job.
Walter
Anthony8858
Jan 24, 2018 01:15 PM
UKcat
May 26, 2017 03:10 PM
David Bedoya
Jan 15, 2017 04:12 PM
djpxk8
Nov 18, 2013 09:40 AM
SirJag
Apr 19, 2011 04:35 AM
