E type ( XK-E ) 1961 - 1975
S2 Heater Box Removal Steps
Old Oct 13, 2022 | 12:19 PM
TigerGuy's Avatar
Default S2 Heater Box Removal Steps
I'm planning to clean up and powder coat the heater box and possibly replace the blower motor while I have it out. I'm relatively new to E-type ownership, so I don't know what exactly I'm up against. Are there any tips or tricks to this effort or preferred sequences in the steps to make the removal/replacement easier? Thanks in advance!
Old Oct 13, 2022 | 07:11 PM
Daytona's Avatar
Hi TigerGuy,
Removing the heater box is pretty straight forward. The thing to keep in mind is that you have the heater matrix/radiator inside the box. So, when you disconnect the coolant hoses it is likely to leak coolant for a while. You can preemptively drain some water from the cooling system to avoid a mess. That aside, you have to disconnect two heater hoses, the heater control cable, the electrical wires to the blower motors, and if I remember correctly four securing bolts. Shouldn't take you long to remove the heater box.
Good luck.
Bill.
Old Oct 14, 2022 | 10:35 AM
OCDHerb's Avatar
Default Gloss or Semi
Was the original paint on the heater box Gloss or Semi-Gloss?
Old Oct 17, 2022 | 09:01 PM
thomn8r's Avatar
I did mine last winter; I had it powder-coated semi-gloss black.
OCDHerb
E type ( XK-E )
Aug 4, 2022 09:56 AM
Willyspu
E type ( XK-E )
Jan 12, 2022 10:53 AM
trosty
Jun 29, 2019 04:18 PM
dennis214
Aug 26, 2014 05:27 PM
psg
Jan 16, 2014 08:21 AM
