E type ( XK-E ) 1961 - 1975
S3 mayday
Old Apr 26, 2019 | 10:21 AM
Thorjag's Avatar
Default S3 mayday
Hi all, I took my S3 down to the gas station to fill her up after the winter. Shes been started every month for a warm up outside the garage. Normal start up and just a mile into town. Filled her up and on the way back she started to run rough añd died 800 meters from home. I suspected coil and replaced that and have spark. New distributor cap and rotor, lead cables and plugs... no life at all when cranking. Plugs are wet and the car smells fuel so this is way beoynd my compentence. What have I missed?
Thor
Old Apr 30, 2019 | 01:19 PM
Fraser Mitchell's Avatar
Have you got a spark from the coil ? As its a Series 3, it is a V12 with the notorious Lucas Opus ignition, sometimes called "Opluss" by mechanics of the time.
Old May 25, 2019 | 12:09 PM
Thorjag's Avatar
The main suspect is me as I found Diesel in the fuel..... Using the same pump as on my XF diesel,, bad excuse but the only one I have! Sorry
Old May 29, 2019 | 11:25 AM
enderle's Avatar
That'd do it. Purging the fuel system... A pain but a lot easier than an engine rebuild. Then you have to dispose of the compromised fuel. Be careful, a lot of folks forget that gas fumes are very flammable.
Old May 29, 2019 | 11:41 AM
Thorjag's Avatar
Yes, got 70 litres of mixture that will be good for bondfire!
Old May 29, 2019 | 07:33 PM
enderle's Avatar
No kidding, but who really needs eyebrows anyway?
NJ2003XJ8
Aug 20, 2016 10:33 PM
jagboy96
Jun 24, 2013 01:53 AM
